Date/Time: Thu, 03 Apr 2025 01:13:27 +0000
Multiple IP's with different Data Feeds
View Count: 382
[2022-12-22 17:43:06]
Meris - Posts: 5
Dear Sierra Charts Team,
I'm planning to start using SC again for running multiple automatic trading systems.
My question would be now, whether I can use my account with package 11 on 3 different PCs (or IPs, since it will be hosted online) with 3 different data feeds (1x Denali, 1x CQG, 1x Rithmic).
I've would run Package 11 and my account says right now "Allowed Systems: 0 out of a total of 3 system(s) are currently being used."
Thank you very much for your help!
[2022-12-22 18:29:47]
John - SC Support - Posts: 39122
You can do this without any additional costs or anything special you need to do. As you stated, you can have up to 3 different computers running Sierra Chart at the same time.
The exchanges work on a different ruleset, but you state that you will only be using the Denali Exchange Data Feed on one computer, therefore you would not need anything special with regards to the Denali data. For future reference though, refer to the information for connections for the Denali Exchange Data Feed here:
Denali Exchange Data Feed: Connections
Just note that in the installations where you do not want the data from the Denali Exchange Data Feed, you will need to set the option for Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds to No and then reconnect to the data feed after you make this change (File >> Disconnect followed by File >> Connect to Data Feed).
