Date/Time: Wed, 05 Nov 2025 05:57:11 +0000
[Programming Help] - Cursor in other instances
View Count: 584
[2022-12-22 17:02:26]
DCSaba - Posts: 113
Dear SierraChart,
First of all Merry Christmas to you all!
Amazing piece of Software, thank you.
Basis of question: I am using a separate INstance with the DOM to place my orders, simply because it is 3-4x times faster than if the saem DOM was part of my Chartbook that has 12 visible and another 20 background charts.
But I love seeing exactly on some charts where I stand currently on my DOM (like the Global Cursor inside of one Instance of SierraChart)
I understand you chose not to write a Global Cursor into Sierra, and that could indeed be a complicated matter.
So I have a simplitic ACSIL code that saves into a file nothing more than just the price level (so no sophisticated time/price cursor, like the Global Curser is), because this is perfectly sufficient on a Renko-kind of chart that I have on my DOM chart (time is of not much meaning, whereas price is).
This code has a "Source" and a "Destination" module and the Source writes into a file the price I point to on my DOM, while the "Destination" module handles this input on my other (bigger) SierraChart Instance and places a dotted line for a short while ontomy selected Charts.
But, it is excruciatingly slow (plus: no matter what time I set the line disappears too quickly). It is sso slow, that I have to stop on a DOM price for at least a second, before it actually reacts on the Destionation side.
I don't understand why that is or if there is anything I could change to achieve a more dynamic reaction?
Thank you very much for your thoughts on this.
All the best,
attachmentGlobal_Cursor.cpp - Attached On 2022-12-22 16:58:30 UTC - Size: 5.68 KB - 298 views
[2022-12-29 03:20:31]
ForgivingComputers.com - Posts: 1154
Try using a RAM Disk.
[2022-12-29 05:37:07]
User183724 - Posts: 194
any disc operation is going to slow things down. you might try 'storing' your info in a temp memory location... like the clip board memory... if you arent using it for anything else.
just as a FYI, sc.FreeDLL is no longer required as of version 1836 and higher.
[2022-12-29 10:15:08]
DCSaba - Posts: 113
Thank you Sir,
I am using a RAM-disk, but I'll try the RAM-memory.
Happy New Year to you.
