Date/Time: Thu, 03 Apr 2025 01:19:00 +0000
bug in Numbers Bars calculated value
View Count: 381
[2022-12-22 16:59:31] |
User233426 - Posts: 4 |
Hello, Please check on SG42 in "Numbers Bars calculated value" The return value of this parameter is always 1 Best regards |
[2022-12-22 18:19:48] |
John - SC Support - Posts: 39122 |
It is properly showing the Price of the Point of Control for the bar in the chart. How are you trying to access the data that you are getting a value of 1? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-22 19:00:51] |
In "color bar base on alert condition" I use this formula : ID6.SG42=1 I get the alert in all bars (Green triangles) This is in "6EH23-CME" Please see attached file |
![]() Attachment Deleted. |
[2022-12-22 19:34:29] |
This is not a bug, but is related to how you have to access the information for the Numbers Bars in a special way when you want to use the values in an Alert. Refer to the 3rd paragraph at the following link for your particular situation: Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
