Date/Time: Thu, 03 Apr 2025 01:12:09 +0000
Converting old chartbook
View Count: 369
[2022-12-22 12:58:15] |
viggomalarafalsari - Posts: 1 |
I need help converting this old footprint. Thanks in advance
Date Time Of Last Edit: 2022-12-22 13:02:15
![]() Private File |
[2022-12-22 14:18:22] |
Sierra_Chart Engineering - Posts: 19049 |
You are able to do this yourself by following these instructions: Chartbooks (Workspaces): Opening Older Chartbooks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-22 14:18:32
