Date/Time: Thu, 03 Apr 2025 01:19:00 +0000
Best study for a bracketed price line study
View Count: 428
[2022-12-21 20:03:14] |
User148596 - Posts: 217 |
Hi, is there a study that would act like the current price line study but have additional price lines above and below the current price at a definable distance away? I'd like to visually see where my standard stop would be on the chart at all times for longs and shorts. I use a 4pt stop so it would basically show a line across the chart 4pts above and below the current price at all times. Thanks!
[2022-12-21 20:28:29] |
John - SC Support - Posts: 39122 |
There are a few different ways to do this. The simplest is to use the Study Subgraph Add study to add the amount to the Current Price Line study. You would need to add however many Study Subgraph Add or Study Subgraph Subtract to get the lines you want. Refer to the following: Using the Basic Arithmetic Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-21 20:31:44] |
Okay great, I'll take a look. Thanks!
