Date/Time: Thu, 03 Apr 2025 01:10:35 +0000
MBO's not showing on 2nd instance
View Count: 332
[2022-12-21 19:38:40]
User216753 - Posts: 19
I've opened a 2nd instance and the symbol setting for the ES are the same
as the primary, but the MBO's are not showing on the DOM in 2nd?
[2022-12-21 20:24:56]
John - SC Support - Posts: 39122
Go through the instructions for setting up the Market by Order data at the following link, for the second instance. See if that resolves the issue:
Market By Order Data: Step-by-Step Instructions
