Date/Time: Thu, 03 Apr 2025 01:10:35 +0000
Historical data problem
View Count: 307
[2022-12-21 16:30:17] |
User427421 - Posts: 41 |
Hello, I recently switched my chartbook to rithmic and I'm having problems with my 2nd instance not getting all the historical data on one of my charts. I tried a bunch of solutions posted but I cannot figure out what's wrong. I left the data settings on the main instance for historical data empty so I can get them from denali...
[2022-12-21 18:30:53] |
Sierra_Chart Engineering - Posts: 19049 |
One thing we see in that screenshot is that you are using a CQG symbol but you say you are using Rithmic. So the symbol is not correct. You can find the correct symbols in File >> Find Symbol.
[2022-12-21 18:48:10] |
I feel so silly, I thought I had switched it... That was the issue, Thanks!
