Date/Time: Sat, 05 Apr 2025 04:43:18 +0000
Données en temps réels CME groupe
View Count: 383
[2022-12-21 16:25:21] |
User522148 - Posts: 8 |
Bonjour, je viens d'activer les donées en temps réels CME groupe, j'ai un compte interactiv broker, cependant je n'arrive pas à les avoirs en temps réels (elles sont toujours en différé), j'ai essayé la manipulation (déconnecter et reconnecter) mais je n'y arrive pas, cela ne marche, merci pour votre aide svp... Cordialement
[2022-12-21 19:49:12] |
John - SC Support - Posts: 39172 |
From Google Translate: Hello, I have just activated the data in real time CME groupe, I have an interactive broker account, however I cannot manage to have them in real time (they are always delayed), I tried the manipulation ( Disconnect and reconnect) but I can't do it, it doesn't work, thank you for your help please
Our system is not showing that you have connected to your Interactive Brokers account. You need to connect your Sierra Chart to your Interactive Brokers account in order to prove your non-professional standing for the CME Group. To connect to Interactive Brokers, follow these instructions: Interactive Brokers Trading Service: Setup Instructions If you are not going to be trading from Sierra Chart and therefore do not need to stay connected to Interactive Brokers, then refer to the following instructions for how to connect at least once a month to verify your non-professional standing for the CME Group: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
