Date/Time: Thu, 03 Apr 2025 20:42:27 +0000
Nasadaq Total View - Stock price in pre market
View Count: 785
[2022-12-21 16:25:02]
User818950 - Posts: 9
have a problem with the stock prices and volume in pre market. The stock VERO has currently (2022-12-21, 07:59am ET)
in Tradingview.com the price of round about 0.485$ with strong volume (> 100K), but in Sierra Chart is the volume of this stock very low and the last price was 6.29$ at 07:52am ET.
Where comes this difference? Have denali data feed with Nasdaq Total View (not delayed).
Thanks.
[2022-12-21 19:45:42]
John - SC Support - Posts: 39148
From the documentation:
The volume for NASDAQ TotalView symbols is only the volume traded on NASDAQ for the symbol. This is only a fraction of the overall volume traded for a particular symbol among the various exchanges/venues it is traded on.
You will find this in the following section:
Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes
[2022-12-27 11:39:10]
User164231 - Posts: 278
Hi John,
I have subscribed to Denali data, as SC said that IBKR data are not accurate.
Is there a quick way to acquire a whole universe of US stocks symbols supported by Denali, so as to import into an associated watchlist for scanning purposes? I would think this list will be useful for someone interested in Sierra Chart for scanning perhaps?
Thanks.
[2022-12-27 20:40:10]
Refer to the following:
Changing the Symbol of a Chart: Automatically Inserting Symbols for Exchange or Index
Note in the above documentation the reference to the "Symbols" menu is the Symbols menu at the top of the window.
Date Time Of Last Edit: 2022-12-28 16:17:50
[2022-12-27 23:32:41]
Thanks John, but I need the whole list of US stocks for scanning, adding one symbol at a time is too tedious especially in this day and age.
Does SC has a full list of US stock im txt for importing please?
Edit : I found an easy way! Please ignore my request
Date Time Of Last Edit: 2022-12-28 02:06:24
[2022-12-28 04:22:23]
Sierra_Chart Engineering - Posts: 19064
The documentation linked to in post #4 explains just how to do this. .
[2022-12-28 06:00:46]
Yes I know that now, the Symbols tab is actually a clickable tab. Perhaps you might want to add '3D shadow' to it like all other tabs for idiots like me.
Last question; how to import NQTV list of stocks?
Date Time Of Last Edit: 2022-12-28 06:17:25
[2022-12-28 15:46:09]
We do not have an importable list for the NASDAQ TotalView stocks.
The easiest way to do this would be to load the list of stocks from the exchange you want and save it out, then open that file with Excel and use the Concatenate function in Excel to add the -NQTV to the end of each symbol and then save that out again with each stock on its own line. Then you can import that file to get your list.
[2022-12-30 07:23:35]
I did just that, all good now. thanks!
