Date/Time: Thu, 03 Apr 2025 01:15:48 +0000
Cancel all Limit orders
View Count: 541
[2022-12-21 15:46:38]
nosast - Posts: 313
Is there a way to quickly cancel all limit orders with a Hotkey?
Like when in a trade an momentum kicks in - instead of trading the limit orders I would rather cancel them with a hotkey but leave the other side of the bracket (stop order) in place.
[2022-12-21 19:43:41]
John - SC Support - Posts: 39122
There is not a specific command that will cancel just the Limit (Target) orders.
The one thing we could suggest would be to setup a line far away from the price that you could then use a hotkey in combination with the Trade Management by Study study. This would then move the targets far away if you do not want them any longer. Refer to the following:
Attached Orders: Study Controlled Targets and Stops
[2022-12-21 21:16:19]
nosast - Posts: 313
I already have something similar with a command to move all targets at once by pressing the right mouse button. Thinking about it, this really could do the job - I just need to have a DOM open beside the chart with a wider scale.
Thanks!
Date Time Of Last Edit: 2022-12-21 21:18:45
