Date/Time: Thu, 03 Apr 2025 01:12:09 +0000
DEPTH OF MARKET LEVELS BINANCE DATA
View Count: 466
[2022-12-21 06:29:12] |
Amelyn - Posts: 46 |
I have followed all of the instructions provided to maximize the amount of DOM levels displayed on the chart, yet it is still very limited (see photo) Tried to change tick sizes, max depth levels, volume at price multiplier, scale settings, all of it.. nothing works. Any insight on what is going wrong? Thanks. https://www.sierrachart.com/image.php?Image=1671604130761.png |
[2022-12-21 18:09:59] |
John - SC Support - Posts: 39122 |
Refer to the following: File Menu: Not Receiving the Full Number of Market Depth Levels But, given that this is a Binance symbol, then that may be all the data we are getting from them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
