Date/Time: Thu, 03 Apr 2025 01:15:49 +0000
overlay trades I took using jigsaw/tradovate onto a chart
View Count: 524
[2022-12-21 06:06:57]
User733806 - Posts: 3
I would like to overlay trades I took using jigsaw/tradovate onto a chart in Sierra Chart.
To that end I wrote a python script that tries to convert from the tradovate format to the sierra format. It does not work yet.
I put the script at
https://github.com/yencarnacion/tradovate2sierra
You can see the current output it produces at
https://github.com/yencarnacion/tradovate2sierra/blob/main/output.txt
The file does not appear to be read when given to Sierra.
I am asking for help on the apparently undocumented Sierra file format
or
If you could point out what might be wrong with the script...that would be even better
Thank you.
I found the following threads which are related
>>> Draw old filled transactions from a csv file onto chart?
>>> Importing trades from jigsaw
[2022-12-21 18:08:23]
John - SC Support - Posts: 39122
The Import format for the Trade Activity Log is the "Exported" format. In other words, do an Export and look at that file to see the format. Refer to the information here:
Trade Activity Log: Importing and Exporting Data
