Date/Time: Thu, 03 Apr 2025 01:12:09 +0000
Session times advice
View Count: 395
[2022-12-21 01:31:14] |
User863386 - Posts: 1 |
What is the correct session times that I should have for my charts if I am in Est time zone ?
[2022-12-21 17:46:37] |
John - SC Support - Posts: 39122 |
Our only recommendation is that you set the Time Zone for your charts to be in the same region in which the time changes occur for Daylight Saving Time. In other words, if you are trading the CME Group, then you would want to be in one of the U.S. time zones that changes times the same as Chicago - so Eastern US, Central US, Mountain US, or Pacific US would all be fine. Refer to the information here: Time Zone Setting: Resolving Differences with the Transition To/From Daylight Savings Time in Different Time Zones For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
