Date/Time: Thu, 03 Apr 2025 01:19:01 +0000
package 12 MBO data
View Count: 669
[2022-12-20 22:49:47] |
Ulie - Posts: 7 |
hello, I recently changed my service package to 12 which should also have MBO data but I am not receiving market depth on the DOM. I would like to know what could be going wrong. If i am not mistaken, package 12 should include market depth as well? thank you !! |
[2022-12-21 17:28:11] |
John - SC Support - Posts: 39122 |
Two items. 1) You are not signed up for any exchanges that include Market Depth data, therefore you will not get the MBO data without this. You can change your exchange selections at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges 2) Make sure you go through the instructions at the following link to setup the items that need to be set for the MBO data within your Sierra Chart: Market By Order Data: Step-by-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
