Date/Time: Thu, 03 Apr 2025 01:20:52 +0000
current bid ask volume columns not showing anything
View Count: 594
[2022-12-20 20:47:41] |
MeowthTradez - Posts: 44 |
It's completely blank and I'm not sure why. Text color is white so it's not the same color as the background. I have volume bars set to show in the customize DOM columns window. Not sure what else to check.
Date Time Of Last Edit: 2022-12-20 20:48:09
[2022-12-20 21:18:28] |
John - SC Support - Posts: 39122 |
Please give us a screenshot of what you are seeing. And also let us know the exact symbol you are using for the chart.
[2022-12-21 00:34:58] |
The CBV and CAV columns are always empty. Looking at ES but have it set to trade on MES. Also there is that white dotted horizontal line that I don't know what that is, I guess I must have changed something some time ago but it's there and I don't know what it is and have been trying to figure that out too. I've looked through graphics settings for entries with dotted lines selected but none of them are match whatever this is. |
Private File |
[2022-12-21 17:38:40] |
Please attach that chart to this thread and we will take a look. Follow these instructions to get us your chart: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-21 23:50:37] |
ok. attached
[2022-12-22 15:14:22] |
Set the option for Chart >> Chart Settings >> Display >> Hide Volume Numbers From Current Traded Volume Columns to No.
[2022-12-22 17:15:00] |
Thank you, are you able to tell me what the thick dotted white line is going across the DOM? it looks like it just draws it there at the price of whenever i open the chartbook and just never moves. edit: looks like the line does move eventually but i don't know what it is... Date Time Of Last Edit: 2022-12-22 18:15:04
[2022-12-22 18:26:30] |
We did not see that line when we looked at your chartbook. Nor do we have any insight as to what it is based on the image you provided of it. You would have to go through the studies on your chart and remove or hide them one by one and see if one of them is creating that line. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
