Date/Time: Thu, 03 Apr 2025 01:17:00 +0000
How to create a symbol that is a calculation of two symbols?
View Count: 406
[2022-12-20 18:09:30] |
Spartan79 - Posts: 54 |
Hi. I want to create a symbol that is a calculation of two symbols, in this case ES/ZB. I did that by adding ES in study/price overlay to ZB chart, then divided them by study subgraphs divide/ratio. Everything looks fine, but I get a line for the newly created symbol. Is there a way to display it as regular candle sticks? Thank you. |
[2022-12-20 18:17:54] |
John - SC Support - Posts: 39122 |
Refer to the following: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-20 19:01:52] |
I just did that and looks good. However is there a way to have rolling contract? When I did {ES}/{ZB} nothing showed up on the chart. I have to do {ESH23-CME}/{ZBH23-CBOT}, but I only get couple days because of new contract. And ESZ22 is no longer traded. Thank you. |
[2022-12-20 21:15:33] |
There is not a way to get a "Continuous Contract" or a "Rolling Contract" for the Custom Calculated Symbols. It is a specific calculation of the symbols that are entered so they have to specify a certain contract.
