Date/Time: Thu, 03 Apr 2025 01:10:35 +0000
can't find ticker symbol "COIN" for the company: Coinbase. it's traded under Nasdaq
View Count: 422
[2022-12-20 16:32:26] |
billym - Posts: 1 |
Hello! I Tried doing a search for coinbase "coin" and nothing it to be found. I tried using the search options for both nasdaq and nyse just in case to be complete but nothing shows up. is this a symbol that cannot be accessed? thank you
[2022-12-20 18:13:32] |
John - SC Support - Posts: 39122 |
The data for COIN is available. Just type in the symbol and open the chart. The search options are not infallible, particularly with stocks. If you know a stock symbol the chances are good that there is data for it by entering the symbol. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
