Date/Time: Tue, 26 Nov 2024 17:22:01 +0000
Unable to log on to second computer
View Count: 1205
[2014-05-30 12:00:35] |
User025429 - Posts: 26 |
I have loaded Sierra Charts onto a VPS but are unable to log on -This log in as exceeded the number od allowed systems - I only have Sierra open on one other computer. Date Time Of Last Edit: 2014-05-30 16:15:02
[2014-05-30 16:13:51] |
To be able to use two systems at a time, you need a direct account: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-30 16:14:34] |
However, in the case of when using AMP/TTNet, only one connection to the trading server at a time is allowed per trading account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-30 18:54:35] |
So if I changed the data feed to Rithmic with AMP I would need to buy a direct package from you, but I could use the Rithmic data from AMP
[2014-05-30 20:30:15] |
Yes.
