Date/Time: Thu, 03 Apr 2025 01:08:59 +0000
TPO chart with VbP only showing one bar per session
View Count: 373
[2022-12-20 16:10:06] |
Ed Levy - Posts: 18 |
I don't remember making any changes. When I check Letters/Blocks In Own Column, no changes are made. Not sure what I did.
[2022-12-20 18:00:40] |
John - SC Support - Posts: 39122 |
Can you please give us a screenshot of what you are seeing, as we do not understand enough from the description. Refer to the following for how to take a screenshot: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-20 18:04:38] |
Hi John, I figured it out. It's in the study itself. I changed the minutes from 1440 to 30. Not sure how it got changed but I got it done. Thank you.
