Date/Time: Mon, 28 Sep 2026 03:35:30 +0000
trade copy from micro to mini
View Count: 1940
| [2022-12-20 14:42:34] |
| william bolger - Posts: 29 |
I have 7 accounts and they all trade fine. Not perfect but fine. I trade them all in the micro es. I want 1 of them to copy trades to the mini ES. How do I do that? |
| [2022-12-20 17:31:02] |
| John - SC Support - Posts: 48028 |
There is not a built-in method to be able to copy a trade for a different symbol. You would have to develop a custom study to do this. Refer to the following for the introduction to custom studies: Advanced Custom Study Interface and Language (ACSIL): Introduction You can trade a different symbol from a chart using the Trade and Current Quote Symbol. Refer to the following: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-01-03 17:15:16] |
I actually did copy from the micro to the mini but not intentionally. Somehow it crossed over but not sure how it did it.
| [2023-01-03 18:03:37] |
| Sierra_Chart Engineering - Posts: 24993 |
Do you still need help?
| [2023-01-03 19:07:02] |
Yes - the link was did not work to trade micro to mini but it is possible because I did it. Thought maybe you could help figure out how. Also, changing update interval to 10ms has all my trades running with no slippage thus far. |
| [2023-01-04 18:24:33] |
We think you are referring to this setting: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-07-22 18:59:50] |
| User936721 - Posts: 32 |
William Did you work out the chart settings to copy micro trades to mini. I’m trading as follows : Account #1 - trading micros This chart is using SC order allocation to copy to account #2 My aim is that when account #1 trades 1x micro I want account #2 to trade 3x minis. I can do this by copying 1 micro to 30 micros, but this is wasteful on commission costs I have sent a DM request to you too? If you can assist I’d appreciate it Thanks |
