Date/Time: Fri, 18 Apr 2025 19:00:44 +0000
Subgraph LineStyle and Width/Size ACSIL functions
View Count: 1048
[2022-12-20 11:52:13]
kas64h - Posts: 87
The ACSIL functions sc.GetStudySubgraphDrawStyle(), sc.SetStudySubgraphDrawStyle(), sc.GetStudySubgraphColors() and sc.SetStudySubgraphColors() have all proven extremely useful.
Is it possible to do something similar through ACSIL functions for Study Subgraph LineStyle and Study Subgraph Width/Size?
[2022-12-20 15:53:44]
John - SC Support - Posts: 39357
These are all controlled through the sc.SubGraph[] structure. Refer to the information for Line Style (for example) here:
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].LineStyle
[2022-12-20 16:27:06]
kas64h - Posts: 87
Thank you for your response.
The functions I was referring to all allow the respective Subgraph properties to be altered in a Subgraph within another study (and/or chart) in the Chartbook - I.E. Function Signature: void SetStudySubgraphDrawStyle(int ChartNumber, int StudyID, int StudySubgraphNumber, int DrawStyle); etc.
This is what I'm looking for in regard to equivalent Get and Set functions for Subgraph LineStyle and Width/Size.
I believe the sc.SubGraph[] structure you're referring to only points to Subgraphs within a study (as referenced by the SCStudyInterfaceRef sc), not 'Other' Studies outside of this too.
[2022-12-20 18:10:29]
The ones you reference are all that are available for accessing other studies subgraph information.
[2022-12-20 20:40:07]
kas64h - Posts: 87
A little over 3 years ago I requested something similar for Subgraph PrimaryColor/SecondaryColor ACSIL functions, which resulted in Sierra Chart introducing the sc.GetStudySubgraphColors() and sc.SetStudySubgraphColors() ACSIL functions (Ref: Subgraph PrimaryColor/SecondaryColor ACSIL functions)
Sierra Chart developed these pretty quickly, so is it possible to introduce equivalent ACSIL functions for Subgraph LineStyle and Study Subgraph Width/Size?
I.E. Something like: sc.GetStudySubgraphLineStyle(), sc.SetStudySubgraphLineStyle(), sc.GetStudySubgraphLineWidth() and sc.SetStudySubgraphLineWidth()
Thank you
[2023-01-15 21:37:06]
kas64h - Posts: 87
Is there any update on this?
Thanks.
[2023-01-17 21:25:44]
Sierra_Chart Engineering - Posts: 19269
We will look at adding these.
[2023-01-22 10:09:37]
These have been added to the latest prerelease.
