Date/Time: Thu, 03 Apr 2025 01:08:59 +0000
Can not get qoutecon META
View Count: 429
[2022-12-20 03:41:16] |
User472677 - Posts: 362 |
I can get quotes in quote board on all socks I want with the exception of META and OPEN.I have deleted these symbols from the data folder and reentered but it does not help.
[2022-12-21 04:31:40] |
Sierra_Chart Engineering - Posts: 19049 |
We see you are using Interactive Brokers. Make sure you are using the complete symbol specification for these: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-21 05:32:52] |
User584084 - Posts: 271 |
Use META-STK-SMART/NASDAQ-USD for the SC symbol for IB data feed. META symbol with TWS API (See Post #7) Date Time Of Last Edit: 2022-12-21 05:37:50
