Date/Time: Sat, 30 Nov 2024 02:30:10 +0000
Hiding Volume Text in Current Traded Volume Columns
View Count: 399
[2022-12-20 03:24:22] |
PolandSpringer - Posts: 30 |
Hello, I am trying to hide the volume text on the recent and current bid/ask volume columns on the trade DOM. I have found an old support thread that addresses this issue: DOM current traded volume bars The link provided (https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#HideVolumeNumbersFromCurrentTradedVolumeColumns) does not lead anywhere and I am not able to find the setting within this documentation. Any help would be appreciated. Thank you. |
[2022-12-20 15:43:18] |
The thread you are referencing was for something that was subsequently removed. There currently is not a way to fully hide the numbers. The only option for this is to set the numbers for the particular column to be the same as the background. But once the Volume Bar gets long enough, you will see the numbers "within" the volume bar (since it has a different color).
