Date/Time: Tue, 22 Apr 2025 13:45:21 +0000
BTC trading
View Count: 969
[2022-12-19 23:56:49]
User989530 - Posts: 34
Is it possible to trade on some exchange BTC/USD BTC/USDT with Sierra Chart?
[2022-12-20 15:25:41]
John - SC Support - Posts: 39395
We do not have connectivity to any Crypto exchanges. We do have data from a few for charting purposes.
We do connectivity to the CME Group for Crypto Futures if you are interested in those. In this case, you would need to use a broker that has support for CQG, Rithmic, or our Teton Order Routing Service in order to trade through them.
[2022-12-28 16:45:41]
So with Rithmic i can trade crypto futures?
[2022-12-28 16:46:12]
Teton is the most advanced order routing system?
In order to trade cypto futures which broker do you recommend?
Stage 5 Trading (Broker)
Edge Clear (Broker)
Trade Pro Futures (Broker)
AGN Futures (Broker)
Canon Trading (Broker)
Sweet Futures (Broker)
DeepDiscountTrading (Broker)
Optimus Futures (Broker)
Date Time Of Last Edit: 2022-12-28 16:53:12
[2022-12-28 18:04:19]
We created the Teton Order Routing Service after spending many years seeing what was not working for other services. In addition, it is part of a whole package created by Sierra Chart including data, charting, and order routing. Therefore, they work better together.
Any of the listed brokers will work, as they all support the Teton Order Routing service. It is your choice on which one to go with.
[2023-03-12 11:37:35]
VLiviu - Posts: 223
Hi all,
So, using sierra chart + one of the brokers listed above (say Edge Clear), I can trade any crypto futures contracts?
Thank you.
[2023-03-13 16:38:50]
The Bitcoin futures on the CME group - Yes. Or any other futures product from the CME Group.
