Date/Time: Sat, 30 Nov 2024 02:30:49 +0000
volume weighted average price
View Count: 405
[2022-12-19 23:37:47] |
coachted - Posts: 329 |
what is the best way to get the actual volume weighted average price...I am getting different results acrosss different charts...for example a 30 min chart is diff than a pnf 1-8 ...both charts are set to intraday and smae zone and same trading times...
[2022-12-20 15:20:27] |
You need to set the Input for Use Underlying Data to Yes. Refer to the following: Volume Weighted Average Price (VWAP) with Standard Deviation Lines: Differences Between VWAP and Standard Deviation Lines On Different Timeframe Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
