Date/Time: Sat, 30 Nov 2024 02:56:43 +0000
I send you the program log
View Count: 356
[2022-12-19 22:14:23] |
AndreyPoroshin - Posts: 104 |
I sent you the program log because I don't filter volume during backtesting
[2022-12-19 23:38:12] |
Where are you setting the volume filtering?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-20 01:11:24
[2022-12-20 11:01:40] |
Sorry, I figured it out, reloaded the data tick by tick. A large amount of volume meant 3 prices per trade, Hight/low/last
