Date/Time: Sat, 30 Nov 2024 04:47:08 +0000
Replay Chart- Reply is Smooth then Slow/Choppy/Jumps Forward
View Count: 598
[2022-12-19 20:13:00] |
PeaceFrog - Posts: 105 |
Hello, Thank you for taking the time to answer my question. When I replay a chart using “Chart-> Replay Chart” with “Replay Mode: Calculate at Every Tick/Trade (High CPU usage)” and “Speed: 30720”, the replay starts out moving along smoothly but then slows down and moves along in chunks or blocks, like it jumps forward. Do these jumps mean that the replay is not moving along at 30720? Does it mean the replay process has slowed down? What can I do to have replay move along smoothly? Thank you very much. I greatly appreciate it. |
[2022-12-19 23:24:30] |
In order to have the replay perform smoothly do not use the option for "Calculate at Every Tick/Trade". As noted it uses a lot of CPU and therefore will be choppy/slow. Refer to the information for replay at the following link: Replaying Charts: Improving Replay Performance / Eliminating Freezing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
