Date/Time: Sat, 30 Nov 2024 04:31:14 +0000
Adding a custom tool config to the shortcut menu
View Count: 321
[2022-12-19 19:56:28]
User414522 - Posts: 19
How does one add TCs to the shortcut menu? For example I use different horizontal lines for different purposes, each having their own TC (TC1, TC2, TC3, etc...) I would like all three TCs on the shortcut menu. Is this possible? Thanks!
[2022-12-19 23:16:37]
John - SC Support - Posts: 36350
There is not a way to do this for the Right-Click Shortcut menu, but you can add Control Bar options for this. Refer to the following:
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
