Date/Time: Thu, 03 Apr 2025 01:15:50 +0000
Charts not Loading
View Count: 855
[2022-12-19 18:36:39] |
Crtfyd - Posts: 281 |
Downloaded latest version 2458 Charts not loading (see attached pic). The screen says downloading contract (its actually not). Only when I "disconnect", then my charts load. I can then "Connect" and the charts download and I am live and everything is fine. There must be a something that was checked or unchecked. What do I need to do to have my charts load and live when I open my chart? Thanks |
Attachment Deleted. ![]() |
[2022-12-19 20:30:58] |
Wait. There may be a lot of data to download. For now reduce this setting: Chart Settings: Days to Load for Intraday Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load menu) Also refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-19 20:32:03
[2022-12-19 21:35:05] |
Yes, you are correct. I have "days to Load" at 90. All, except overnight were previously downloaded, so I figured it doesn't have to download more than overnight to bring it up to date. I did wait a bit, and they still didn't load. I thought I tested loading less, like 7 days and it didn't load Sunday night. But I closed my SC after changing to 7 days to load right now, and it did load upon opening. So knowing I already had the 89 days info, why wouldn't it load? Is there a pre-set number of days that wont load LIVE? Or are you saying if I waited long enough, they would've loaded (which confuses me bc I already have the 89 days of data in my file). Thx (btw, I did read the support info, but couldn't see anything applicable for the above reasons) |
[2022-12-19 23:30:48] |
John - SC Support - Posts: 39122 |
We can not say exactly what occurred. We wonder if there may have been a change to the Continuous Futures Contract setting, which would have needed different data for different contracts if that was not set previously - so that would have been different data that needed to be downloaded. If something like this occurs again let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-22 02:18:49] |
So I found several days in my 90 days loaded with missing data. So I thought I'd just do a EDIT/DOWNLOAD DATA to just get a clean download of data. I erased my data in my DATA file for ESU22_FUT_CME.scid and ESU23. I reconnected, but my chart only goes back to 12-12. Coincidentally, which is the rollover day. I thought, maybe its one of my settings. My Chart Settings is set to "Continuous Futures Contract-Volume based Rollover". Automatic Rollover Futures Symbol=NO. Then I thought, is it bc Im doing "Edit/Download Data Intraday Chart"? bc Im doing this after hours 6:11pm PST, so its historical? I now wish I left the data alone. But there must be a setting that is making it so I cant get data past ~10 days even though I have DAYS TO LOAD at 90. Ive since switched to 60, thinking 90s was right around the rollover from Z to U, but still only loads back to 12/12. Thx |
[2022-12-22 15:16:46] |
Follow the instructions at the following link and let us know if you still have issues: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Instructions to Download/View More Historical Intraday Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
