Date/Time: Sat, 30 Nov 2024 04:50:41 +0000
Live Equites data
View Count: 260
[2022-12-19 15:50:19] |
pampolpops - Posts: 12 |
I currently am subbed to nasdaq totalview with Denali but obviously it does not have the full data set of market data. If I am looking for primarily market delta type data is there more comprehensive real-time data I can use via sierrachart/denali? I do not necessarily need market by order for realtime stocks
[2022-12-19 22:17:01] |
You can use the Sierra Chart Exchange Data Feed with the U.S. Equities exchange. Follow the Setup Instructions at the following link: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Note that the above data does have the consolidated tape, but it does NOT have Market Depth data. Once you have the above exchange activated, you would use the standard stock symbol for the data (i.e. IBM, not IBM-NQTV). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
