Date/Time: Tue, 26 Nov 2024 17:23:45 +0000
CL CALENDAR SPREADS
View Count: 1462
[2014-05-30 09:45:47]
Meritus - Posts: 164
Please can you explain what adjustments I need to make in order to see exchange listed (NYMEX) calendar spreads for CL. Currently in "Find Symbol" under CL there is no option to select the calendar spreads for CL though I can see the list of individual expiration months going forward. I am using the CQG feed to trade. I am aware there were some issues a while back with TT Fix users and their ability to see calendar spreads, which was resolved. I'm just wondering if I need to make changes or whether it's something you need to look into. Thanks in advance.
[2014-05-30 09:50:12]
There is currently no support for exchange listed spreads on CQG. This has to be developed. It is not something which is very simple to do.
We will check on this though.
