Date/Time: Thu, 03 Apr 2025 20:34:39 +0000
Incorrect ES Pricing Data after Rollover
View Count: 605
[2022-12-19 15:29:46]
tfh6252 - Posts: 20
This has occurred again with the rollover from ESZ2 to ESH3. A back adjustment of -.75 needs to be made.
I've followed the above instructions
Continuous Futures Contract Charts: Instructions for Entering Settings for Controlling Rollover Amount
Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments
Additionally, after attempting the commands listed below, I Downloaded current SC version and Manually deleted all .scid files and reloaded. I then issued the commands again, reloading data after each command.
This looks to be a syntax format issue. Please indicate the exact command required to fix. I've tried ESZ2-CME=-.75, ESZ2.CME and ESZ2 with and without spaces preceding and following the "=" sign. No command is taking effect.
Tom
[2022-12-20 15:54:58]
Sierra_Chart Engineering - Posts: 19064
We see you are using Rithmic. So the symbol would need to be:
ESZ2.CME
And what is the name of the field that the rollover adjustments are entered into? And you need to enable Use Custom Symbol Settings Values on the Symbol Settings window.
[2022-12-22 00:43:20]
tfh6252 - Posts: 20
Now, back to my original question:
What is the command syntax? Are there any spaces? Like this: ESZ2.CME=-.75 or, ESZ2.CME= -.75 or ESZ2.CME = -.75 ??? I've tried all of these with no solution.
Tom
[2022-12-22 05:14:34]
Spaces should not matter but perhaps they could affect the symbol. Would be best not to use spaces.
This is correct:
ESZ2.CME=-.75
We would have to add more logging to help isolate the issue you are having.
Date Time Of Last Edit: 2022-12-22 05:14:41
[2022-12-29 19:11:06]
The additional logging is already there. Do you see a message like this in the Message Log:
"Adjusting price difference from _ by user specified amount of _ to".
