Date/Time: Thu, 03 Apr 2025 00:31:11 +0000
Please I need support - The Quoteboard is not showing the list of symbols
View Count: 479
[2022-12-19 11:07:47]
User314484 - Posts: 9
Dear support,
I am new to SierraChart. The chartbook I have attached is showing that the DOM, which is empty and the Quoteboard is not showing the list of symbols. I tried to write down the new contrats in the column "Symbol" and it wont allow me to save. I suppose this is were the issues start and it is normal that I cant see any data coming into the different DOM. Please, I need to your help so that I can start my journey with SierraChart.
I have attached the charbooks.
(please ignore my previous to emails)
Thanks a lot
William
attachmentChartbookDOM.Cht - Attached On 2022-12-19 11:06:38 UTC - Size: 20.56 KB - 108 views
[2022-12-19 18:56:59]
John - SC Support - Posts: 39122
The main thing we see that you need to do is to open the Chartbook and then select "Edit >> Translate Symbols to Current Service". This will change the symbols in the Chartbook to what you need for the service you currently have selected.
