Date/Time: Sat, 30 Nov 2024 01:46:51 +0000
Bid ize and Ask size Column doesnt work properly
View Count: 467
[2022-12-19 06:11:42] |
User414932 - Posts: 9 |
Hello Support team Help me please i have a problem with DOM Why my Bid size and ask size column doesnt show a full number of ask and bid size fully like in the left side column ? the right side column have only number of bid side 1 1 and ask side 1 1 and the recent bid and ask volume show only very small value is that normal or abnormal ? WHy it doesnt show bid&ask value like 100 350 500 or 1000++ like other column? |
[2022-12-19 18:50:05] |
That is because CFD contracts do not have that data. You need to use YM futures instead which is available as Delayed Streaming Data from the CBOT. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-19 20:08:06] |
Refer to: Delayed Exchange Data Feed Use: YMH23-CBOT Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-19 20:08:24
[2022-12-22 06:41:01] |
Yes there is US30 US Dow Jones Index chart in CBOT but there is one problem The US30 Dow Jones chart in CBOT sevrer the chart doesnt look same like in trading view or meta trader 5 US30 and in CBOT chart is look so different in CFD FXCM server does have same chart like in trading view and Meta5 but they dont have data to support DOM Is there anyway to help me to find a chart like what i looking for sir? |
[2023-01-03 05:00:25] |
Sierra_Chart Engineering - Posts: 17266 |
No. We just have the US30 CFD symbol from FXCM without depth and the CBOT YM futures. You could have a look at using LMAX data: LMAX Trading Service You can set up a demo account with them and use that data. Sierra Chart does support LMAX data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
