Date/Time: Sat, 30 Nov 2024 02:55:53 +0000
How to get daily chart with weekly profile?
View Count: 498
[2022-12-19 03:14:00]
User963128 - Posts: 5
Hi, dear,
I want to get daily chart with weekly profile ,how to do that, which study to use?
thanks a lot!
Private File
[2022-12-19 18:45:00]
John - SC Support - Posts: 36350
You use the Volume by Price study and set it to display Weekly profiles. Refer to the following:
Volume By Price Study: Time Period Type for 'Fixed Time'
[2022-12-21 10:14:53]
Thans, I get it.
By the way, how to hide or cancel someday's market profile?
[2022-12-21 19:38:37]
In general you can not remove a single TPO from the chart. But, if you really want to do this, then you would need to add the day to the list of "Dates to Exclude". Refer to the following:
Chart Settings: Set Dates To Exclude (Button) (Chart >> Chart Settings >> Chart Data >> Chart Data menu)
[2022-12-26 01:13:41]
thanks so much,
best regards.
