Date/Time: Sat, 30 Nov 2024 02:37:17 +0000
Daily OHLC-Single Point study - request
View Count: 395
[2022-12-18 20:18:45]
User316362 - Posts: 210
Extending the H/L values with lines works well. The only issue is that the extension line for the H/L values are the same color versus the color of the High and Low values.
Can you just change this to extend high and low colors.
Basically we need a way to have the extensions for the H/L colors be the same colors as the High/Low Colors. Like
color the high extension lines RED and color the low extension lines GREEN?
Another thought is to be able to select the overnight session independently instead of just daytime session "OR" Daytime & Overnight. there's more flexibility if either or both can be chosen.
Thoughts?
Date Time Of Last Edit: 2022-12-19 19:38:29
[2022-12-22 15:43:42]
Any thoughts on this?
[2022-12-22 19:56:38]
is source code for this available in one of the studies library?
[2022-12-23 09:07:14]
Sierra_Chart Engineering - Posts: 17267
Yes you can modify this study to meet your requirements.
Refer to:
How to Build an Advanced Custom Study from Source Code
[2022-12-23 16:22:20]
I found the code in Studies8.cpp , Thanks much. I can take it from here.
