Date/Time: Sat, 30 Nov 2024 02:55:53 +0000
CME with market depth for non-professionals - Tradovate instead of interactive brokers
View Count: 776
[2022-12-18 01:17:52] |
plutus1901 - Posts: 29 |
Hello, In order to get the, we need to have a trading account. However, I do have a trading account with interactive brokers but I was unable to connect my interactive brokers account with sierra chart because I am using a commission free trading. I do also have a tradovate account. Can I please know if I can connect my tradovate account to SC so that I can get the "CME with market depth for non-professional trading accounts" Thank You |
interactive brokers issue.png / V - Attached On 2022-12-18 01:16:02 UTC - Size: 88.18 KB - 91 views |
[2022-12-19 04:33:14] |
Yes you can use tradovate. But they need to set you up on the CQG system to connect: CQG Trading Platform Service They may charge you extra for that. This is also another solution you can use that only has a fixed cost of 100 USD: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-19 04:33:47
[2022-12-27 02:28:27] |
Hello, I have created the stage5 account and I have connected my sierra chart account to stage5 account for 1 minute and reverted the change back to "SC data - all services" to qualify for non-professional CME exchange fee. Can I please know how can I check if I am getting the CME exchange data for non-professional rate or not. Thank You |
[2022-12-27 04:40:34] |
Sierra_Chart Engineering - Posts: 17267 |
We can see that: Verified trading account ending date: 2023-01-22
The next step is for you to complete the agreements and activate the exchange you need here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
