Date/Time: Thu, 03 Apr 2025 00:31:11 +0000
Study overlay
View Count: 509
[2022-12-17 21:29:07]
User575399 - Posts: 326
Hello, I have a 5 tick Renko chart with a number bar calculated study that I want to overlay onto a 10 tick range bar chart .
When I try to overlay that study it changes both charts to a range bar chart even though they are not linked . How can I make this work ? Thanks !
[2022-12-18 19:25:33]
Any ideas ?
[2022-12-19 18:20:36]
John - SC Support - Posts: 39122
You can not overlay the Numbers Bars Calculated Values study.
It is possible to display data from a different chart in the Numbers Bars Calculated Values study, but to do this the Bar Period has to be exactly the same and the system will adjust the period to make them match. It sounds like this may be what you are coming across. Refer to the information at the following link:
Numbers Bars: Overlaying a Numbers Bars Calculated Values Study from Another Chart
