Date/Time: Thu, 03 Apr 2025 00:32:09 +0000
run sub instance from cmd
View Count: 389
[2022-12-17 18:40:06] |
User61576 - Posts: 445 |
is there any way to run sub instance from cmd using a command line?
[2022-12-17 20:20:28] |
Sierra_Chart Engineering - Posts: 19049 |
Yes. Just simply run the Sierra Chart executable in the sub instance folder where it is located.
