Date/Time: Thu, 03 Apr 2025 01:16:59 +0000
Chartbook not compatible
View Count: 562
[2022-12-17 13:06:51]
User314484 - Posts: 9
Dear Team,
My chartbook file giving an error of not compatible kindly contact Sierra chart support team for converting it. I have attached the file kindly convert it or fix it so I can use it in my sierra chart. Thanks.
Private File
[2022-12-19 15:52:53]
John - SC Support - Posts: 39122
Attached is your updated chartbook.
attachmentDOMCHARTBOOK.cht - Attached On 2022-12-19 15:49:52 UTC - Size: 20.57 KB - 109 views
[2022-12-19 16:14:40]
Dear John,
Thank you very much for your help. The file is now compatible. However, the Quoteboard doesn't allow the list of symbols to appear on the column "Symbol". I have tried to enter in that column the contract "ZNU22-CBOT", when I press on "Ok", I still see nothing register. Please help me solve this problem.
Regards
William
[2022-12-19 22:34:42]
There is nothing different about the Quoteboard in terms of having updated the chartbook. Therefore, when you are wanting to enter a symbol by selecting the field under the Symbol column, you need to double-click on the particular field and then it will give you the ability to enter the symbol for that field.
Or, you can enter a list of symbols by selecting the Symbols item on the Quoteboard menu and then entering the symbols into that window. Refer to the following:
Getting Quotes: Setting Symbols
[2022-12-21 12:38:34]
Thank you very much. All is okay now.
