Date/Time: Thu, 03 Apr 2025 00:31:09 +0000
Replay problem with jump method
View Count: 444
[2022-12-17 11:36:23] |
Jupitersbay - Posts: 54 |
Trying to use the Replay Jump by Time method in the actual version. It seems not to work (see screenshot). How can you jump forward 60 minutes in the reaplay? |
[2022-12-17 20:11:49] |
Sierra_Chart Engineering - Posts: 19049 |
We do see a problem with this. We are checking on this.
[2022-12-17 20:56:10] |
We know what the problem is. You cannot use 60 for the minutes. You need to set the hours to 1 instead. So you need to use: 1:00:00.000 We will be sure the documentation makes this clear. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-17 20:56:28
