Date/Time: Thu, 03 Apr 2025 00:31:10 +0000
How to transfer to graphic setting from one chart to another
View Count: 870
[2022-12-16 20:18:10] |
User278794 - Posts: 13 |
I have made a Chartbook with all my settings. I have two other monitors that I would like to put charts on, but I don't want to just detach charts and put them on the other monitors I want to have a whole other chartbook on the other two monitors, but I want to be able use the settings that are saved on my current chartbook on the other chart books on my other two monitors.
[2022-12-16 21:42:07] |
John - SC Support - Posts: 39122 |
Chartbooks are not detachable, so the only way to really do what you want is to use multiple instances. 1 instance for each "Chartbook" you want to have for each of the other monitors. To do this, you would use the option for File >> New Instance. Refer to the information regarding Sub-Instances starting at the following section and through the rest of that page: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Source of Data for Sub Instances As noted in the above sections, the data will be copied from the main instance the first time, therefore the Global Graphics Settings will also be copied, so you can use those to get the charts setup the way you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
