Date/Time: Thu, 03 Apr 2025 00:32:09 +0000
Bad links and suggested updates for ACSIL_Members_Functions.html
View Count: 511
[2022-12-16 19:54:04] |
User719512 - Posts: 307 |
Hello SC Team, Bad links and suggestions for ACSIL Interface Members - Functions Summary: Fix links for sc.UsesMarketDepthData Update struct s_MarketDepthEntry snippets Add a help topic to explain struct s_MarketDepthEntry members including the difference between Price and AdjustedPrice. sc.UsesMarketDepthData links point to: https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#scUsesMarketDepthData should be: ACSIL Interface Members - Variables and Arrays: sc.UsesMarketDepthData For example: ACSIL Interface Members - Functions: sc.GetAskMarketDepthEntryAtLevel struct s_MarketDepthEntry Updates: struct s_MarketDepthEntry
{ float Price; t_MarketDataQuantity Quantity; uint32_t NumOrders; } should be: struct s_MarketDepthEntry
{ float Price; t_MarketDataQuantity Quantity; uint32_t NumOrders; float AdjustedPrice; } |
[2022-12-16 20:48:32] |
Sierra_Chart Engineering - Posts: 19049 |
Thank you will do this
[2022-12-17 22:26:57] |
Thank for fixing this documentation for the benefit of all developers. The information is there and looks accurate. FYI, there are some minor formatting/alignment issues if you care to address them. There are 4 locations for "struct s_MarketDepthEntry" and they are potentially indented too far (but aligned), or indented as expected with the first 3 fields indented too far. |
