Date/Time: Thu, 03 Apr 2025 00:32:10 +0000
can only go back 24hr for replays/
View Count: 393
[2022-12-16 19:00:21]
User449884 - Posts: 167
Why is it that i can only replay the prior day for replays?
[2022-12-16 21:34:17]
John - SC Support - Posts: 39122
You can replay starting from wherever the data in the chart starts.
Check to see if you have the option for "Use Start Date-Time" enabled on the Replay window and therefore you are always starting from the entered Date/Time.
Otherwise, we need to know how you are starting the replay, what kind of replay you are starting and how much data is loaded in your chart.
