Date/Time: Thu, 03 Apr 2025 00:31:12 +0000
Study Subgraphs Reference study returns/references incorrect values
View Count: 532
[2022-12-16 18:07:14]
Sawtooth - Posts: 4196
The Study Subgraphs Reference study is used for shading between two subgraphs that are not in the same study.
However, this study seems to return the incorrect values, and the shading does not match the referenced subgraphs' values.
The attached Reference of two lines.png shows two lines at 3900 and 3910, but the shading is from 3864 to 3932
The attached Reference of tow MAs.png shows the shading above the higher MA and below the lower MA.
Note: The Study Subgraph Reference study accurately returns the referenced subgraph's value.
Please advise.
imageReference of two lines.PNG / V - Attached On 2022-12-16 18:05:31 UTC - Size: 32.71 KB - 102 views
imageReference of two MAs.PNG / V - Attached On 2022-12-16 18:05:43 UTC - Size: 48.6 KB - 102 views
[2022-12-16 18:21:59]
John - SC Support - Posts: 39122
Set the scale of the Study Subgraphs Reference to "Automatic". Refer to the following:
Chart Studies: Settings and Inputs Tab >> Scale
[2022-12-16 21:40:38]
You would think that would be the default.
[2022-12-16 21:47:18]
You can make it the default by using the Set Defaults option. Refer to the following:
Chart Studies: Using Custom Default Study Settings
