Date/Time: Tue, 01 Apr 2025 22:06:43 +0000
chart disappering
View Count: 328
[2022-12-16 16:29:53] |
User951676 - Posts: 8 |
I have tried to find answer on support board with no luck. I have a chart book with an ES chart and NQ chart. When I try and drag or scroll the chart to the left for Es with the hand on the screen it immediately disappears. But I have no issues with my NQ chart in the same chart book.
[2022-12-16 17:08:41] |
Sierra_Chart Engineering - Posts: 19040 |
Might be related to the Scale Range being used. Make sure to use Automatic: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-16 17:09:02
