Date/Time: Tue, 01 Apr 2025 22:07:56 +0000
plate forme
View Count: 333
[2022-12-16 16:27:16] |
User436656 - Posts: 2 |
Bonjour Je ne trouve pas comment avoir les onglets en bas du graphique !! Ces onglets son situés en dessous de l'heure ! En cliquant sur ces onglets ca me permet de changer de graphique très rapidement au lieu d'aller dans " CW" Merci d'avance Best regards Marc |
[2022-12-16 17:20:44] |
John - SC Support - Posts: 39080 |
From Google Translate: I can't find how to have the tabs at the bottom of the graph!! These tabs are located below the time! By clicking on these tabs it allows me to change graphics very quickly instead of going to "CW"
Thanks in advance Refer to the settings for the "MDI Tabs" at the following link: General Settings Window: Window Tabs (Global Settings >> General Settings >> Windows) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
