Date/Time: Tue, 01 Apr 2025 22:07:56 +0000
[Programming Help] - Automated trading order problem
View Count: 337
[2022-12-16 15:42:33]
User650203 - Posts: 6
hello, I use an automated trading system, when I'm in sim the orders work well and when I'm in replay it works well too. But when I am in real live account, the trading robot does not activate and take the position.
[2022-12-16 16:21:46]
User900285 - Posts: 98
From how you described it, if you are using ACSIL to do automated trading in Sierra Chart you might be missing this line in your program.
sc.SendOrdersToTradeService = !sc.GlobalTradeSimulationIsOn;
Search for sc.SendOrdersToTradeService in the SierraChart\ACS_Source folder to see different ways that it is used in the examples.
By default I think it is 0, therefore without that line your system will not work for sending orders to the trading service you are connected to.
