Date/Time: Tue, 01 Apr 2025 22:07:56 +0000
Large Volume Trade Indicator Study on Numbers Bars
View Count: 506
[2022-12-16 13:03:19] |
User513662 - Posts: 91 |
Hello, Is it possible to run the Large Volume Trade Indicator Study on a chart with the Numbers Bars study to display large trades that take place at certain price levels on the ladder? I cannot seem to make it work. Many thanks. |
[2022-12-16 16:46:00] |
John - SC Support - Posts: 39080 |
You can definitely use these together. The only issue you may run into is that the Numbers Bars could overlap the markers from the Large Volume Trade Indicator. You will need to take a look at the various placement options to see what you can do to make the view the best for your setup.
