Date/Time: Tue, 01 Apr 2025 22:04:45 +0000
Format external trades log to fit Sierra Charts format
View Count: 442
[2022-12-16 04:39:05] |
funbun - Posts: 90 |
I'd like to review my equity trades on the charts, while the execution happens on an external broker. I've read the Trade Activity Log on the documentation but there's no mention of the right formatting of equity trades in order to properly import them to SC. What is the right formatting? |
[2022-12-16 16:07:27] |
John - SC Support - Posts: 39080 |
The format you need to Import is the format in which the data is Exported. Refer to the information here: Trade Activity Log: Importing and Exporting Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-16 17:09:22] |
As I mentioned in the previous message, that info is not in this section. I need the headers and all possible values for these headers and their format (UTC time zone for example, how to represent it?) |
[2022-12-16 17:12:43] |
Sierra_Chart Engineering - Posts: 19040 |
The information is not in the documentation. You have to create some fills through simulated trading and export them. And then look at the format of that file.
